Noob Looking For Advice
  • BrewhousePizza
    • Dec 2013
    • 2
    Hello,
    I decided to join the forum after deciding to research starting a Brick Oven Pizzeria at my microbrewery in Texas. I am currently reading The Bread Builders but I'm sure I'll have plenty of questions as I learn.
    A little about myself: My brother and I have been homebrewers for years, and are now getting the chance to start a production microbrewery. We are only a few weeks away from production, and are expecting some big crowds on the weekends during our tasting events and tours. We have a very nice outdoor sitting area for tasting, so I'm looking to add a WFO for artisan breads and pizzas as well as ambience for the whole facility.
    Our investors are not interested in adding a restaurant to the facility, so I am looking to do this on my own. I will do some more reading in the commercial section, but any advice or resources would be greatly appreciated! I'll start a thread about my project once I get past the research stage and share my experiences with the community.
    ~ Brent
  • jeeppiper
    • Mar 2011
    • 321
    Re: Noob Looking For Advice
    Brent:
    We have a place nearby called "The Vault" (Vault Brewing). These guys converted an old bank into a microbrewery. They put in a commercial pizza oven (no kitchen) and serve food to complement and "wash down their beer". It is a really great combination... I think you are wise to complement your beer with some food....but not too much that it take attention away from your beer. It also allows you to pair your beer with the correct food. Good Luck!
    • Tscarborough
      • Oct 2009
      • 3341
      Unless you plan on baking mostly bread, do not build the oven described in the book. You will get better service form a Pompeii or low dome Neapolitan, depending upon what type of pizza you plan on serving.
      • BrewhousePizza
        • Dec 2013
        • 2
        Thanks for the info! I was thinking about doing a Pompeii style. Are they hard to make look nice?
        • the_dr_masuess
          • Jul 2013
          • 177
          The finished product look will vary but the two most common styles are the dome look and an enclosed look. You will have to decide on placement inside or outside but normally for commercial applications I've seen that the ovens are enclosed and when you enclose the oven the possibilities for for the way it looks are really endless. You can rock, brick, or stucco the outside in any pattern you prefer and with any material. You can make it as expensive or cheap as you want depending on the finish material you use. 1 option you have is to do it cheap to start and then later on finish with a more expensive look. I'm not to the point in mine yet where I'm finishing but when I get there I will build an enclosed structure and probably just stucco the outside to start and in the future when more funds are available I'll rock it up.
          Loren
          My Build - http://www.fornobravo.com/forum/f8/n...ney-19648.html
          SLOB - Salt Lake Oven Builders - For WFO builders in Utah - Join here http://www.fornobravo.com/forum/grou...-builders.html
          • Tscarborough
            • Oct 2009
            • 3341
            As stated, the oven (the engine) is totally independent of the finish of the oven. You can make it as simple or as detailed as you want.
            The actual part that is used for cooking is beautiful inside no matter what type you build, but the exterior is 100% up to you.
              All very great! advice! I really like this by Tscar
              To me, WFO ovens are like women, they are all beautiful on the inside, but great curves outside are what turns heads ................. Whutt..................., If you were expecting calendergirlsdotcom, you will have to do that search yourself, this is a family oriented forum .
              • Greenman
                • Feb 2013
                • 1123
                Beauty is in the eye of the beholder. Personally I like the exposed dome shape but that is a personal thing. It is also relatively easy finish that way. Many of the enclosed ovens that have been displayed here are works of art and testament to the considerable skill and patience of the builder.
                Like most things in life, the innards do the work and the exterior is just cosmetic. Even ugly ovens can make great pizza.
                Cheers ......... Steve
                • CV_Oven
                  • Oct 2013
                  • 48
                  Absolutely one of the enjoyable parts of oven building is being able to tailor the look to fit whatever design works best for the owner. The options are nearly endless.
