Hi, I recently moved into a house with what looks like an outdoor wood fired oven. It's 19.5" wide, 32" high and 23.5" deep. It seems to be made of regular household bricks, has a cast iron door with 2 close-able vents, no chimney (and no obvious way to retrofit a chimney). I'll post pictures if I can figure out how. Would love thoughts from all you experts about it - is it usable, will I kill myself with the smoke since there is no chimney, will it retain heat for baking, is there anything special I should do since it seems to be pretty different from recommended designs? Thanks!
Laura
Laura
