Here is a link to an old post that may help.
Originally posted by Karyn B View PostHi JRPizza. But what is the tool you used to cut the curve? Forgive my lack of tool knowledge...but I cook a mean pizza!My build thread
Edit - I just read the post Gulf linked to - what I was trying to say but much more clear!My build thread
Originally posted by david s View PostThe OP just wanted to know what to substitute the clay with for the sand/clay underfloor leveller. This thread has taken on a whole new direction.
The term "fire clay" is used in the US for any cheap powdered clay used in the building industry generally as a mortar improver. To a potter the term "fire clay is a totally different animal. It is a clay that is designed to withstand extremely high temperatures, (very low in impurities and fluxes, large clay particle size and high in alumina), expensive and certainly way beyond the needs of WFO builders, in terms of service temperature. A powdered clay has extremely small particles and is not cementious, i.e. it does not react chemically at ambient temperature (that begins at 573 C), so it should really be considered an aggregate in a mortar or concrete mix. Because the unfired clay particles are so small they induce shrinkage (typically on its own up to around 10% wet to dry) particularly if used in a large proportion in the mix. Once fired and crushed the particle size is increased enormously and the shrinkage proportionally reduced. This stuff is called grog not fireclay. (well it could be fired and crushed fireclay). The slurry left by the brick saw is also fired clay but the blade cuts it so fine that the particle size is far smaller than crushed fired clay (grog). However the particles of the saw slurry are still way larger than most unfired clays and this would explain why it works so well as a mortar addition with a lower shrinkage.
ps. stay away from Bentonite as it has extremely small clay particle size and has a very high shrinkage rate.
Thanks,
David (another David S in fact)
David in Calgary
My Build Thread
Thanks David
I've got mine in a big-ish Rubbermaid bin that I used as the water reservoir for my saw. I've just syphoned out the water in hopes the water can evaporate & leave mainly dry cuttings to mix this weekend. (we shall see if May heat in Canada is warm enough for that purpose)David in Calgary
My Build Thread
Dig it out of the container and spread it out in thinner layers. It will dry much faster. I sieve mine with a normal window screen. And, yes there will be some cuttings that get through the screen which are much larger than dust size. I replace some sand with cuttings in the ratio for that. I don't know if it matters that much.2 PhotosJoe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
