Ones build dilemma
  • Ones build dilemma
    Hi everyone I’ve decided to try build a oven everything seemed to be going smoothly till il got to the last couple courses I was to focused on trying to have tight gaps and my last couple courses got ugly I think I should have used a form from what I’ve been reading with the remaining hole I have can I just fill it with whatever I can get in there
    If you could post some pictures of what you have built so far folks could offer up better suggestions on how to get finished.
    My build thread
      Will do mate was just waiting for my post to be approved
        Lots of folks end up with strange shapes at the top of their ovens. I ended up with a seven sided plug- see link below. You could hold a piece of cardboard up against the ID of the hole and trace the shape, then transfer that onto a plug. Might take a few pieces. Just don't do like I did and make the fit too tight. A light tap and I knocked some flakes from the adjacent bricks.
        I've been working on my oven for a little while and have been debating starting a build thread, as I probably won't have much to add in terms of artistry or inventiveness over the excellent work already posted on this forum. That said, I thought I would share what I have done and hopefully continue to get
        My build thread
          I was always under impression that it had to be a perfect keystone at the end and it got tricky and I think I got impatient as well I might try what you said
            Yup, the imperfections just gets amplified with every course. You see keystones in all shapes and sizes.
            The pizza will be just as good.
            take your time to cut your unique keystone. It will probably take half a dozen dry-fits. Make the inside face first with cardboard. And It’s okay if the (invisible) outside gaps are wider.
              I’m not sure if I can get it out of one brick the outside gaps could be quite large
Name:	54H Plugging the Dome 8.11.12.JPG
ID:	443759 Click image for larger version
Name:	54I Plugging the Dome 8.11.12.JPG
ID:	443758 I does not have to be one brick, my plug was three pieces, the lower or internal one piece the upper or outside was two pieces. So speaking of being impatient. Do step back and take a deep breath. It is later part of the builds the builders get in a hurry, wanting to get the project completed, This especially true when curing the oven. Take your time.
                . Click image for larger version
Name:	54F Plugging the Dome 8.11.12.JPG
                  yes I definitely needed to take a deep breath and step back your last few courses look primo mate
