I embark upon the jouney and the journey is the destinationi
  • berryst
    • Jun 2008
    • 184
    I could have read a how-to book ...but I haven't
    I could have studied and planned but didn't
    There are, before me, thousands of years of technology and the wisdom of millions who came before me.
    I fear no evil. But I did watch utube! God help me I've started to build one of those wood fired ovens
    I started with a barrel of wine. It was empty or the oven would have to wait. I cut it vertically. This forms my arch. It is beautiful in its taper, its graceful arch so perfect in size the universe seems to be in harmony. No fluffing around with those other arches. No! Just plunk it down cover it in brick and fill in the gaps for me. Bingo a 24 x 30 floor.
    At least that is the plan or should I say folly.
    But, first I had to deal with that blasted platform. Now those platforms look like a lot of work to me. So I just skipped that part. I just dug out a platform out of the sand bank just behind my back door.
    My 6x7 foot pad is in. Lots of re bar Next, A rather pathetic stone wall to hold the bank up under hearth. Eventually I will cover it all with dirt and plant harmony on top. This way it will just look like a hearth with a hole in the wall the oven hidden under the earth.
    ?????MY FIRST QUESTION?????
    Has any body heard of per-lite board... its used in roofing under torch down. Would this work? Or would this rather friable board be to soft? I would like to use it under the firebrick under the oven chamber. Help? I would like to start on the brick tomorrow.
    berryst
    sigpic
  • Ken524
    • May 2007
    • 1655
    Re: I embark upon the jouney and the journey is the destinationi
    Barry,
    I can't help you with the per-lite board, but your oven sounds interesting. I can't wait to see the pictures of this thing. Please post pics!
    Ken H. - Kentucky
    42" Pompeii
    • berryst
      • Jun 2008
      • 184
      I'll try some pics but I'm not to savey on posting pictures...old school I guess.
      Not much to see at this point still waiting for something to go terribly wrong.
      Berryst
      sigpic
      • CajunKnight
        • May 2008
        • 263
        Welcome aboard Berry, sounds like you have something going there. Let us know how it works out.
        like chicken...
        My 44" oven in progress...
        __________________________
        • berryst
          • Jun 2008
          • 184
          Still looking for someone who knows if perlite board will work to insulate may slab.....any takers>
          Berryst
          sigpic
          • brokencookie
            • Oct 2007
            • 376
            All the perlite boards I found were similar to this.
            1. A perlite-based insulation board comprising:
            between about 50% and about 76% by dry weight expanded, perlite;
            between about 15% and about 45% by dry weight fibers wherein between about
            50% and about 95% by dry weight of said fibers are recycled newsprint
            fibers and between about 5% and about 50% by dry weight of said fibers are
            virgin cellulose fibers which have not been subjected to chemical pulping
            to remove lignin;
            about 1% to about 5% by dry weight binder; (this is probaly some kind of glue)
            about 2% to about 9% by dry weight bituminous material; ( This is asphalt ) and
            about 0% to about 3% by dry weight alum.
            On the basis of this I would give the product a pass. It looks like they are using it for roofing insulation. Low temperature stuff. Even though it will not be heated directly, it will be in contact with hot fire bricks. The standard perlite concrete used for Pompei ovens is a combination of concrete and perlite-- all pretty much non-flammable. I would say it's not worth taking a chance on. Making perlite concrete is pretty cheap and easy. If you would rather has the ease of using a finished board product, buy the FB insulating ( ceramic) board. A small investment in a good product will prevent many problems down the line with your oven.
            Bruce
            • berryst
              • Jun 2008
              • 184
              Bruce
              Thank you for your informed reply. Perlite is hard to find around here. It can be ordered but this takes time. My instincts were to NOT use the perlite board but its cheap and available....will keep looking thanks. Your timely reply is greatly appreciated.....and no its not raining in the pacific northwest today ....don't know what to make of this!
              Berryst
              sigpic
              • brokencookie
                • Oct 2007
                • 376
                Last week we had spring, this week summer. Next week we might have winter again. I'm in Olympia and the weather is stranger than the politicitians.
                You can also use vermiculite. It might be a little easier to find. Many times you can get it at garden centers or nurseries. Another option would be aireated concrete (AAC) or insulating concrete. Some of the guys on the forum have used this without a problem.
                I urge you not to get too far ahead of yourself. If you look through the posts in the forum you will find that short cutting your insulation leads to wailing and sack cloth later. The FB chant is Insulate, Insulate, and Insulate again. There can never be enough insulation.
                There is a supplier of industrial insulation in Kent. I can't think of the name right off the top of my head but they should be in the phone book.
                Bruce
                • brokencookie
                  • Oct 2007
                  • 376
                  I found it
                  Bay Insulation Supply of Washington
                  7043 South 190th Street
                  Kent, WA 98032
                  Phone: 425-251-6750
                  Fax: 425-251-6225
                  These guys have everything
                  Bruce
                  • SpringJim
                    • Apr 2008
                    • 562
                    Bruce
                    I'm not sure that we should use the "perlite concrete" terminology. It's actually a mixture of portland cement and perlite which is a mineral, not a gravel and more like a sand and dust mixture!
                    Mortar is usually sand and cement. Concrete is sand, cement and gravel.
                    I'd say what we're using is perlite mortar but it's usually an insulation layer...doesn't act much like mortar...so what's a good terminology?
                    It seems to be structural and we're putting a ton of weight on the hearth layer too!
                    just my obtuse brain musing......
                    • SpringJim
                      • Apr 2008
                      • 562
                      by the way, sounds like a barrel oven
                      have you thought about how will you get the barrel out after the bricking is done .... you don't want to damage the new oven!
                      Jim
                      • Frances
                        • Aug 2007
                        • 2186
                        Well, you light your fire and the barrel burns up... I'm assuming its a wood barrel you're talking about here, right?
                        • berryst
                          • Jun 2008
                          • 184
                          Its always a good day to burn barrels in Washington. That mean that the oven is complete. That's how I plan to remove the barrel....in ash!
                          I will however use the barrel to create an arch opening in the hearth...kinda of a flared Arch entryway that the flue sits in/on. This is the plan any way. I'm still waiting for everything to go seriously wrong but so far so good my foundation is in.
                          After looking at the beautiful work of others its guys like me that make them look even better.
                          I tried masonry once before I thought my wife was gonna leave sure..had enough I figured but after 28 years later shes still hanging around. I'm a pretty good lawyer for a cement mason.
                          I'll try to post a pic so you can all feel better. So that you can all say well at least I did a better job that that poor b****** His wife should have got out while she had a chance.
                          sigpic
                          • berryst
                            • Jun 2008
                            • 184
                            [IMG][/IMG]
                            [IMG][/IMG]
                            [IMG][/IMG]
                            [IMG][/IMG]
                            sigpic
                            • berryst
                              • Jun 2008
                              • 184
                              sigpic
