getting started
  • cookerman
    • Apr 2009
    • 3
    getting started
    Well, I'm over the retirement thing and am starting an oven in the backyard. I'm a building contractor in Southern Calif. and things are a little slow right now.
    My question regards the amount of insulation needed over the firebrick of the dome. The instructions say in one area that the firebrick alone would be enough while the other areas of the instructions call for insulating blanket with perlite concrete over. Wondering what most people are doing for thickness of the walls and type of insulation? I'm planning on pizza and bread.
  • Ken524
    • May 2007
    • 1655
    Re: getting started
    Hi Cookerman. Welcome!
    My dome is covered with 3-4 layers of 1" refractory blanket then the vermiculite concrete over that. I even have some blanket over and around the entry arch area. You can't have too much insulation.
    I'm not sure where the instructions say fire brick is enough. If there is a spot where your oven could lose heat, insulate if possible. Exceptions are of course the front of the entry and landing.
    Ken H. - Kentucky
    42" Pompeii
    • DrakeRemoray
      • Mar 2006
      • 1215
      Re: getting started
      In short, the more insulation the better! Make sure you insulate under the hearth as well as over the dome. Are you planning to build an igloo style or more of a house-type structure? I have a stone house structure and in addition to 2-3" on blanket, I filled the whole house area with loose vermiculite. It retains heat for a very long time.
      Drew
      My Oven Thread:
      • james
        Brick Oven Merchant
        • Mar 2005
        • 4648
        Re: getting started
        Ken and Drew, you guys are great. Good advice.
        • CajunKnight
          • May 2008
          • 263
          Re: getting started
          enjoy your build, i know i am.
          like chicken...
          My 44" oven in progress...
          __________________________
          • exceloven
            • Aug 2008
            • 279
            Re: getting started
            Cooker,
            You have found the right place for all the advice you'll need. Where are you in SoCal? There are 3 or 4 of us in the San Diego area.
            Mark
            • cookerman
              • Apr 2009
              • 3
              Re: getting started
              Thanks for the help on the insulation. I am building an igloo style. Just started the blockwork for the base yesterday.
              I am located in Cardiff by the Sea
              • Neil2
                • Oct 2006
                • 1374
                Re: getting started
                I didn't use the blanket material. I used a tin foil layer then 5 inches of vermiculite concrete (12:1 mix). I have 4 inches of 8:1 mix under the hearth firebrick.
                It holds the heat well. We had pizza yesterday for super and, as I write (11:00 AM) the oven temperature is still 250 degrees. My wife is letting it cool to 200 degrees before putting in a slow cook sirloin roast for tonight's supper.
                • exceloven
                  • Aug 2008
                  • 279
                  Re: getting started
                  Cookerman
                  I used the FB blanket then added about 4" of vermiculite over that. It has worked very well for keeping the heat in. BTW I am in Oceanside, I just finished a job in Cardiff yesterday. It was on Summit Place. Looking forward to your pics
                  Mark
