Outer covering of oven. . . .
  • Bob Denton
    • Feb 2009
    • 2
    We have built a beautiful oven out of firebricks and now it's time to cover it. We have heard everything from cement to stucco but have no idea what material is best and why.
    Can someone help us?
    Thanks,
    Bob
    Jalisco, Mexico
  • CajunKnight
    • May 2008
    • 263
    Re: Outer covering of oven. . . .
    Let your conscience your guide!!!!
    like chicken...
    My 44" oven in progress...
    __________________________
    • DrakeRemoray
      • Mar 2006
      • 1215
      You need insulation first...make sure you have that before you put your final finish on...
      My Oven Thread:
      • thebadger
        • Jun 2007
        • 383
        I went with the dome via the stucco route. I couldn't find stucco in cin ohio so I used Type S mortar (per Quickrete recommendation). Worked well but I'm still developing some hairline cracks a year later through by Behr masonry paint. If I could do it again I think I would use Quickwall (from Quickrete - surface bonding cement) first and then maybe cover that with a type s mortal.
        Good luck.
        Dick
        • Jochen
          • Aug 2008
          • 25
          I bought an insulation blanked from the same place that had the fire bricks and fire clay. The stuff is rated up to 1600 degC. It was quite expensive but if you really want to retain the heat I think it is worth it. Above that I put a 10cm layer of vermiculate/cement mix.
          As a finishing render I used a mortar mix with plenty of PVA and water proofer. The PVA makes the mixture really stick and easy to work with.
          As the weather can get really bad here in the UK a used a good quality masonry paint at the end.
          The isolation properties of the oven still amaze me. Even after hours of making Pizza the outside just does get even warm.
          • Neil2
            • Oct 2006
            • 1374
            I used an acrylic stucco.
