Does anyone know, after you are done with the dome, wraping it with chicken wire then hi temp mortar, before you add the blanket. will it help with the strength of the dome? I searched for some answers but can't seem to find.
Chicken Wire Before Thermal Blanket
Re: Chicken Wire Before Thermal Blanket
I don't think you are going to get much additional strength, the mortar will add thermal mass, I put the chicken wire over the blanket to hold it all smooth. Strength of the dome shouldn't be a concern, I'm sure you could stand and jump on top of it without worries.
E
There is also some thought that, as the melting point of zinc is 420 C, the galvanizing on the wire might degrade and the wire could corrode anyway. It's buried under there so who's going to take a look? The idea of the chicken wire over the blanket is to hold it in place and to provide some strength for the vermicrete layer.Kindled with zeal and fired with passion.
I personally did have a few fires before I put on blanket due to the fact that I was just impatient. Having said that though I had the big fires once it was all on. It won't crack the outside because the blanket allows the oven to expand and contract without putting any pressure on outer layer.
That is true, but I think the greater problem is moisture in the insulation layer turning to steam and creating enormous pressure. I believe that this is what creates cracks in the outer shell. Therefore cure after insulation (particularly if you use vermicrete or perlcrete because they take up so much water) and before stucco.Kindled with zeal and fired with passion.
