Ok, I'm totally a newbie on this and am learning as I go. I have built my stand (a corner model) for an angled 42" oven. I poured the concrete slab for the hearth base and then the perlite/portland cement mix to the specs outlined in the plans. The perlite mix goes right to the edges of the hearth.
My question is this: Given the structural limitations of the perlite/portland mix, what are my options for putting a finishing layer on the hearth to protect against moisture, or alternatively, can I build up walls and a roof on top of the hearth? Will the perlite/portland mix hold up with the weight?
In retrospect, I probably should have formed it off to limit the perlite to just beyond the perimeter of the dome, but it is too late for that.
Any thoughts sincerely appreciated.
