Cleaning Dome Mortar
I am building my first oven and would like to know how am I going to clean mortar from the inside of my dome if I use a foam board form? I am sure that the mortar is going to be quite hard before I can clean it. Also how wide can the mortar joints be if I use the Forno Bravo mortar?
Tags: None
Re: Cleaning Dome Mortar
you could try Sure-Klean or some of that sort read the directions before that though good luckProfessional cleaners in Hornsby could be the right answer of all of your domestic issues.
Dent, I appreciate the help from down under. I am more concerned about the mortar that will surely collect on the inside of the dome . Since I am going to use a foam board mold, I will not be able to remove the excess mortar as the bricks are laid. How do people that use molds of any type clean the excess hardened mortar from the inside of the dome? I would like to use a mold as I am obviously not a mason. I made my living in the engineering world. I did the drawings. Getting a picture?
Originally posted by pappap View PostDent, I appreciate the help from down under. I am more concerned about the mortar that will surely collect on the inside of the dome . Since I am going to use a foam board mold, I will not be able to remove the excess mortar as the bricks are laid. How do people that use molds of any type clean the excess hardened mortar from the inside of the dome? I would like to use a mold as I am obviously not a mason. I made my living in the engineering world. I did the drawings. Getting a picture?
chipChip
Or a simple vane. You do need to clean as you go or you will be spending a lot of time with a grinder and acid. Keep the gap to a minimum. That requires cuts, some have choose not to do so and their ovens work just as well. It's just a matter of preference.Check out my pictures here:
Hi
I used a plywood dome guide... was mindful of the excess mortar and was still able to wipe most blobs as I went. When finally burnt out (the Fun bit) I found only a few blobs here and there....which were easily knock off
Trust me after the first pizza you will no worry
Regards DaveMeasure twice
you can try muriatic acid, but you have to be careful, it etchesProfessional cleaners in Hornsby could be the right answer of all of your domestic issues.
I've crawled into my oven once....its not for the fainthearted......but to go in with acid now that scares the "Bejesus" outa me
Originally posted by dent ford View Postyou can try muriatic acid, but you have to be careful, it etches
Chip.Chip
I got awfully concerned about the "unsightly stains" on the inside of my oven, even starting a similar thread on the subject of cleaning them off:
I did spend some time laying on my back feeling claustaphobic inside my completed oven dome with a wire brush attachment on a power drill. After covering my hair, face and probably lungs with powdered mortar (and the odd chunk), I realised that despite the effectiveness of the technique, it really wasn't worth it.
My advice would be to not get too carried away and spoil the fun of the build worrying about such minor details. See what's left after your curing fires and if you you're still worried, then an hour with a wire brush will probably get rid of anything significant.
Good luck.------
Poops
Currently building first oven with red brick base
FB plans plus Russell Jeavons book
