I have read quite a few posts here and looked at other sites also. My question lies in the bricks, I have the chance to get over 1000 red bricks for free as long as I load and carry. The possible problem is these bricks have 3 holes in them and I am assuming that they will not be sufficent for use as a main component of the oven. I know I can use them to finish the oven but not anywhere heat might transfer. Am I correct?
Bricks, I need some insight
Re: Bricks, I need some insight
1000 bricks sounds like a great stand to me.......
Regards DaveMeasure twice
I was always told by the old timers that the air that may be trapped in the holes would expand and explode the brick, sounds like crap to me though.
I have seen old baked, not fired, bricks used in fireplaces that have stood up to the test of time, there really isnt a reason when you think about it why a wire cut brick shouldnt be used.
(The old baked bricks are doughy and easily crumbled, fired bricks are hard and vitrified.)Last edited by brickie in oz; 08-31-2011, 02:33 AM.
The composition of the brick is more important. Bricks containing more than 5% iron oxide for instance are more brittle. likewise a high proportion of silica in the clay is undesirable. Looking at brick or breaking it with a hammer is no indication of what it contains. Generally the higher they are fired the stronger they'll be, but a firebrick can often be way weaker in strength than a solid standard clay brick. Insulating firebricks for example can be easily broken with a few taps, yet are probably good for 1300C+ and will not spall from heat.
A forum member, from Africa, if I remember correctly, used wire cut bricks with holes in them and filled the holes with clay (ant hills I think) this essentially gives you a solid brick and should work ok. I can't recall if he ever reported back re the success or failure of this experiment. A 50/50 sand clay mix should cope with the tendency of the clay to shrink in the holes.Kindled with zeal and fired with passion.
