I am back building my oven. I have done the key stone and given the whole dome a thin 10mm coat of homebrew to make it more even before the ceramic blanks go on. I used a sand form for the final 5 layers. I got lazy and it seemed to be the easy way to go. Worked well enough, however the mortar is not as neat in the top layers as the rest.
When you look inside some of the mortar did not get all the way down and as smooth as the rest. Just in some places and you have to have your head in the dome to see it. I have no thoughts of it falling down. Seems very strong to me, just not as neat as the rest.
Is there any reason beside looks to crawl in and try to get some mortar into any gaps?
Is doing this going to cause this new mortar to fall into pizza later on?
I want to start some SMALL fires very soon (been a week since last mortaring was done and seems very dry) to get the thing cured well before wrapping the blanket on as I will be rendering the oven as soon as the ceramic blankets are in place to stop loose fibres being a problem.
If you read the MSDS for the blankets,, you'd be scared to use it. Iwill be going full asbestos type suit and masks when doing it !
If the blanket was not so cheap for me I might not have gone this way..
Has anyone had to tidy up the inside??
ROb
ROb
