Anyone have thoughts on the materials used for the oven floor? Does this have to be brick? Can it be granite? I have seen some posts about soapstone. Any thoughts on pros and cons of all? I was thinking it might be good to have a one piece floor rather than all the seams of bricks. But I don't know the heat threshold of granite or its insulating properties. Thanks.
Re: Oven Floor Material
You can use granite on your entry outside the oven, but a granite surface is supposed to deteriorate under higher heat ranges.Lee B.
DFW area, Texas, USA
