Re: Info on a corner build for an outdoor kitchen
The extra thickness of the hearth means nothing to the performance of your oven. You are going with 4 and a half inches of fire brick which suggests that you are interested in thermal mass to preserve heat for multiple cooks. More insulation will benefit you there. It does not have to be 4" of vcrete. It can be 2 more inches of FB board or CalCil. Each are equal to 4" of vcrete. I will go back to what I origionally thought your question was. "Does anyone think that I could get away with not using the fiber board?" At the very least use the FB board or some form of insulation under the oven.
Originally posted by spitfirefd
View Post
. 5-1 for vcrete is correct for under the oven. I don't think that you will regret the extra oven floor height.
