Re: oven stand size
Wise words. Go as big as you can, you won't regret it.
You should be able to obtain vermiculite or perlite, which will make an effective insulator base for your calsil boards. This is what I did, and the next morning, I cannot feel any heat under my support slab from a 900F oven the night before.
But, insulating under the oven is the most important. You could even go a little bigger
), I would have split treated studs on the table saw for framing.
