Newbie Design
  • Newbie Design
    Hi,
    I do not want to build a traditional clay oven but one out of bricks.
    The plan would be a 1m x 1m x 1m square oven with fire bricks on the inside surrounded by 50mm fireblanket and an exterior of clay brick to match the house and garden.
    The roof of the oven to be Vermiculite board with fire blanket and sand over it also. A 50mm hole in this for a small chimney and paving slabs with a chimney to complete the exterior.
    It is to be buit on 350mm concrete foundation with vermciculite as a base with 30mm sand for the fireslab oven floor.
    How much is wrong with this plan?
    Dave
    Re: Newbie Design
    The ceiling and vent inside the firing chamber.
      Re: Newbie Design
      Thanks for the reply so quickly!
      OK no chimney and firebrick the ceiling, then Fireblanket?
        Re: Newbie Design
        Move the chimney to the front outside the opening, if you want one, and firebrick the ceiling, yes.
          Re: Newbie Design
          Understood,thanks!
