Hi,
Based in South Africa. Standard size firebrick is extremely expensive here (equivalent $3). However, 1inch thick firebrick is not too bad - $1 each. Planning on building a low dome barrel style.
So I was thinking. What if I built the floor and dome out of the 1inch firebrick, and then built a structure under the floor and around the dome out of solid clay overburnt bricks. Total inches will be 4inches in total floor and dome.
Could this work? Everything else will be in place (vermicrete hearth, insulation blanket, etc).
Works out to around $50 more than doing standard fire brick floor, and clay brick dome, or around $400 dollars cheaper than complete standard fire brick.
