I am planning a build for this spring/summer.
I want to build a steel stand instead of masonry block.
I plan on using fiberglass insulation board to set the oven floor on.
I am wondering if it is recommended to pour a concrete slab on top of the steel frame? If so how thick?
or is there another type of surface/material one could use in this construction method?
