So I know there is a ton of information in the forum about foundations and footers. After reading it all I'm still a bit confused. Some say build a footer and other say do not. The building department is confused as to if I even need a permit for the project. So here are some details to begin.
I'm in Norther Virginia and the frost depth is 18" officially however, I'm told it's better to be at 24" as winters here very greatly for severity. I'm in the planning phases right now and want to build a 42" oven. so here are my questions.
1. If I dig a footer does the entire "slab" have to be 24" deep or just a parameter (can I leave a column of dirt in the middle)?
2. If I pour a footer and build up with cinder block from the footer should I mortar and fill the cores or can I dry stack it and then fill the cores?
3. Does the cinder block need to be treated with any surface coating like a foundation wall would be painted?
Thanks in advance and I'm excited to get the project started if the rain ever stops and the clay decided to allow the water to drain away a bit.
Jason
Jason
