Hello all. So after the build or my Premio110, it would appear that I used a tad too much sand as a base for my floor/cooking surface. The result is that after the dome was assembled, the dimensions of the opening are not not as high to accomodate the oven door. I did grind the metal on the door back as much as I could yet its still to difficult to get the door in without it getting stuck. A friend who works with concrete suggested I use a diamond cup on my grinder to "Lightly" take down some of the cast refractory surface. because of the black soot on the surface I am able to see where the door scrapes, so I have a good indication of the exact spots it would be good to gently run the grinder over.
My two questions are this:
1. This all makes sense on paper but is there any issue that anyone sees? Im talking about taking a couple millimeters off, really not much.
2. While I would make sure to vacuum the dust out, just as one would do with ashes, is the dust from the cast refractory material a hazzard if a neglagable residue was still on the cooking surface, even after a thorough sweep and vacuum?
Thanks everyone.
Thanks everyone.
