Thank you so much for this forum!
Oven is assembled and ordered a few bags of Heat Stop dry mix and wanted to use this to cover the oven and fill the gaps. Would this be wise as I see most using a stucco covering with a heat blanket. Because of the thickness of the dome wall (2" plus 1" of firebrick) I truly didn't see the heat blanket as necessary.
What can I mix with the Heat Stop to properly secure gaps and protect from weather?
Mahalo!
Mahalo!
