Just starting to plan an oven build this coming spring. I came across this roughly 150 yr old cast iron warming oven door that I'd like to use on my oven(see pic). It is 12" tall and 16" wide. I want to insert this door into a wood frame that would extend the width to cover the opening and add an arch to the top. Is there an issue with building the opening the proper size (I plan on buiilding a 36-40" diameter oven so door opening 12" high X 19" wide and then make the vent arch etc larger to accomodate this door? It would result in a 2-3" door jam instead of a 1". Thanks.
Marc
Marc
