Hi All, I am building my first oven (its been on the to do list a long time) and have some questions around the design. I have an old open fireplace in the garage (house was built in the 50's and original owner built plywood racing boats so threw offcuts in the fire, heated the house, ran the wetback, and generally kept him warm. I don't build boats and have no need to keep my car warm so am converting it to a pizza oven which can use the same chimney.
The attached pic is what I have so far, the base layer of refractory bricks is on a thin layer of sand, below that a layer of tin foil and below that 250mm of concrete (then the garage floor which is probably 150mm thick). I asked my question about insulating the walls/roof on another forum and the only reply I got was that I should insulate the floor more. I hindsight that would be great but that ship has sailed so hopefully I can get some more information to help complete the build here.
Once I have laid the refractory bricks for the walls/roof I will grout with fire mortar. My Question is what should go on top of this insulation wise? i.e. do you use a layer of render, then some insulation like vermiculite mixed with concrete, then tin foil? and then more render?
Or can I just use Vermiculite/concrete mix straight on the bricks? What would be the ideal thickness
Many thanks for your help. I have posted some pics of the layout I am going for. Because of the opening in the wall and size of the garage I was a bit limited with design options but any constructive feedback would be appreciated.
. My appologies and condolences for the price of fire brick in your country. If you can't source the extra brick as RussellI advises, I'm going to suggest something that is a little above my paygrade. I think that you can lay the entire oven as shiners. But you will need to add a 2" thick cladding layer for thermal mass and for some structural strength. You can form the side walls to achieve that. The roof can be just applied to depth. If you can source some fireclay, you can make a home brew with portland cement, hydrated lime, fireclay (brickies clay), sand, and the cuttings from your saw to clad the vault. For the sides, you will probably have to sandwich the vault with a ridgid insulation between it and a stretcher laid face brick for buttressing. That insulation could be vermicrete, perlcrete, calcium silicate board, or ceramic fiber board insulation.
