Rusty,
Leveling your stand with sand for your fiber board is probably just fine. As long as it is not so thick that it can not be contained and could sift out at the edges. If it is that thick, you might would want to go for the extra insulation that a vcrete layer will offer (that also means waiting on the vcrete layer to dry). That is up to you, and also what your finished height will allow. I'm not sure why you would need to further level the firebrick on top of the fiber board. Most, level the oven floor brick with fireclay. If you lay your oven wall on top of the fiber board, you can use mortar where needed to level them. If you are laying them on top of the oven floor brick, a thin (no stick layer) is usually used. I've seen aluminum foil or newspaper used to keep the mortar from sticking to the floor brick. I would guess that parchment or butcher paper would work just as well.
Note: I like the practice of a moisture barrier between the hearth slab and the insulation layer. I also like the practice of elevating the insulation layer above the hearth slab.
I hope this helps.
I hope this helps.
