My oven is going to be under the edge of a patio roof. If I ran the flue straight up, it would hit the ceiling, so I will have to add some angle pieces to move it back withing my enclosed structure. The pipe will run up directly along side the roof edge. From read the duravent installation manual and old posts it seems that the following are true:
1. The top of the flue should be 2' higher than any roof within 10'
2. The flue needs to be 2" away from the edge of the roof assuming I'm using double walled
Is this correct? On number 2, I'm guessing that I would use some sort of bracket that would attach the vent to the roof yet hold is 2"+ away?
Also, is there a minimum distance the flue needs to run vertically out of the oven before I add bends to start moving it back? I'm going to be using a casa90.
Should I use double walled the whole way or just for the section adjacent to the roof? If only for the section adjacent to the roof, how close to the roof would I switch from single to double?
Lots of quetions for this newb! Thanks for the help!
