Hello,
I searched and searched. Apologies if I had missed something obvious. There are many options for insulation, it seems. I want to build a 36" Pompeii. This is for the home, occasional weekend parties. I imagine we'd want to get it as hot as 850F? Instructions suggest 2" insulating ceramic fiber board, and 3" layer 1" ceramic blanket. I'll mesh/stucco over that
Is this sufficient to achieve 850F+ (or should I be using more insulation in either floor or walls)?
Why do people combine other types of insulation with this approach?
Should I be trying to figure out if there are better options (bang/buck)?
Should I be worried about health concerns of the ceramic insulation post build (maybe if my seams on the inside aren't tight enough, etc)? In other words, should I do something (foil?) between the dome and the blanket?
PS. (It actually occurred to me that these blankets should not be compressed, so I am a bit confused about what happens when you stucco over them? You just use heavy, not very sparse mesh?)
Thank you very much, and sorry for many questions.
