I have a FB Casa2G100 oven that I had installed last fall by a local stonemason/landscaper. It's built into an outdoor fireplace made of granite blocks (pictures below). I've done maybe 10 pizza cooks in it. Last night, we did another cook, and had a major problem with bringing the oven up to temperature. The dome was fine - over 1000 degrees as measured on my IR thermometer, but the floor wouldn't get above about 450 degrees, even after burning a hot fire for about two hours. In the past, it's taken about an hour to get the oven up to temperature. The problem was pretty clearly due to water having gotten in behind the oven. I had water visibly leaching out through the mortar above the door. There was also water leaching out through the oven wall itself above the opening to the oven. Also, the ceiling of the fireplace below (which is below the floor of the oven) was warm - 150 degrees as measured on my IR thermometer
So, my questions are:
* Is this a problem others have?
* Any thoughts as to how the water got in? My theory is that it is due to rainfall coming down the chimney, which then puddled and leaked under the oven door, and then soaked in through the gaps between the bricks in the floor.
* Any idea how to get the water out? I'm wondering if I should just burn it out by running a hot fire for - how long...? But by forcing steam out through the mortar between the bricks, could that cause damage? I wonder if drilling a hole up under the floor would let the water out.
* It seems like I need a cap over the chimney. Is that what most people do?
* Is there any permanent damage? I'm picturing that the insulation is now soaked, and might not work well anymore, even after it dries out.
Thanks. I'm planning on meeting with my contractor this week, and need some info to bring to the meeting if I'm going to confront him about how they screwed up.
- Dave
- Dave
. I guess that the two uncapped liners on either side of the vent are for the fireplace. Without knowing how it is designed, that is probably another mega source of water for your flooded oven. Get a cap to cover all three and while your contractor is there get some spark arrestors installed. I would still like to see another couple of pics from a level slight above above the the first tier step in. I can't tell If a sloping bed of mortar was installed from the pics. All of the advice you have recieved from everyone above is great! Don't "can" any of it. You have a complicated setup. But, I am sure that we, as a forum, can get your oven back to specs
