Offset chimney design?
  • Offset chimney design?
    Hi Guys,
    I am very new to this forum and am currently doing a load of research into how to build my perfect Pizza Oven. I am planning on building a 40" Pompeii but I want to offset the chimney so it rises from the center of the dome. I am also planning on building a secondary brick dome around the ovens insulation similar to the image shown here. Has anyone on FB actually tried a build like this???
    Most people seem to just insulate and render the dome or build the oven into some kind of box/ housing.
    Would love to see any pictures or hear from anyone if you have done anything similar and hear how it worked out for you!
    In a previous response I mentioned that a beaver or squirrel tail vent needed for chimney like you want. Do a search on the forum for beaver or squirrel tail. There was a recent build similar to the pic you posted.
      UtahBeehiver Thanks for the reply... Sorry I missed your comment about the beaver/squirrel tail vent.
      Do you know if they are harder to get the draw on the fire working properly?
        There are quite a few builds where the final dome finish was brick - check out Gulf's magnificent Mississippi Queen. The front of his oven is different from what you are looking for, but the dome is very well done in brick.
        https://community.fornobravo.com/alb...sissippi-queen
        As Russell mentioned above, you are either going to have to build a vent that wraps around the top of your oven (fairly complicated build) or put a direct vent in your oven chamber which will result in what I believe is an inefficient oven in terms of heat retention. I would suggest you poke around on the forum and find a pompeii style oven that you really like the looks of. There are plenty of beauties to emulate.
        My build thread
