Our story so far:
Mortared the soldier course using the following method;
- Put down an aluminum foil layer around the perimeter of the floor
- Dry fit the soldier course on the foil
- Mixed up approximately 5 pounds batches of the FB mortar to a peanut butter consistency
- Soaked the soldiers for ~ 5 minutes
- Buttered the side of the ½ soldiers on the side that would contact the previous soldier
- Used a water spray bottle to mist the previous brick
- Pressed the brick into position.
- Tap the new brick with a rubber mallet
- Rinse and repeat so 30-odd times
If I had it to do over I would not have buttered the brick up to the oven-facing edge but started around the middle of the brick running the back edge. Would use paper and not foil to keep the bricks from adhering to the floor and diatomaceous earth for good measure. Ended up with a puny brick in the final reel after dry-stacking a number of times (see photo).
Took the first 5 soldiers down as I did not care for the texture of the first mortar mix and some separation of brick/mortar occurred. We have had a few nights of significant freezing, a least for southern Arizona (16 degrees F), and wanted to see if that would separate the bond between mortar and brick. So far so good.
Ordered the Angleizer but it looks like General Tool does not support the software anymore (https://community.fornobravo.com/for...ndows-software). Any thoughts about another source for the software?
Another question; would the internal/external arches be mortared onto the floor or free-float like the solider course?
Jlo...
, it only raised up two edges so that putting things in was no problem but when you pull ashes out there is a catch on the floor. No big deal and a little grinder action there would be quick and easy...but it just hasn't been worth getting in the chamber with a grinder.
I really think that type of installation problem is what the Forno Bravo guide is meant to cover. The use of sand/fire clay to help set the floor is really all you need. (Use a mister to lightly dampen the media, then run a notched trowel over it...this is just like setting a tile floor in the house. The grooves created by the trowel give you the ability to tap/adjust each brick down level with the adjacent bricks. The moisture will help to firm and "set" the sand/fire clay base so things don't move around later.
