What do I use to cover dome - final layer? - Forno Bravo Forum: The Wood-Fired Oven Community
  • What do I use to cover dome - final layer?
    Total noob question.
    What options do I have to cover the chicken wire and insulation blanket?
    Thanks in advance.
    So as I didn't hear, I went ahead an bought heat stop. Is that overkill with a blanket in place? Was certainly expensive!
      I would say it depend on what you used for insulation, my ovens use 4 of ceramic blanket and are covered with a 4-1 sand cement mix.
      The outside of the domes are rarely above ambient temperature.
        I put the wire over the blanket and then covered it all with about inch mortar. After that I applied a product called Dryvit. It stands up well against the weather and you can get any color you want.
