G'day All,
Hope all is well living in these crazy times. I posted a few questions a few months ago in preparation to the hearth and insulation steps but it got too hot to lay concrete. With the cooler weather now I can get going again. I am still undecided on which way to go and would appreciate any feedback.
I have 7 inch available for hearth and insulation. The oven floor and dome bricks will then be on the insulation, therefore planning around 3 and half inch for the hearth and around 3 and half inch for insulation layer. I'm thinking perlite and/or calcium silicate board for insulation. Full perlite would be easy enough but LOTS of posts say more insulation is best and whilst I don't plan on cooking bread I'll make the best oven I can within the 7 inch. Alternatively I thought of having 3 by 1 inch layers of silicate board directly on the hearth but I have a few concerns about going this way, numerous comments about not having oven directly on the board and I'm concerned and led to believe if the board did get wet it could collapse then, ALL bad. However will perlite do the same thing?
Has anyone used silicate board under perlite, in this case I would have 1 inch board under 2 and half inch perlite? I'd be happy with that amount of insulation, but would this work?
Any thoughts/recommendations appreciated.
Kind Regards.
Kind Regards.
...because it's difficult to lower the floor temp in a short amount of time.)
eliminate water getting into my insulation "wrap" of my oven is to build an enclosure that provides a good roof over its head (and mine
