Hi All,
I have built my dome using a mix of 5:1 perlite/cement fondu, with a cement fondu/sand render over the top. In the next few weeks I intend to cover with insulation blanket (secured with chicken wire) and finish with a waterproof render and paint.
If I knew what I know now, perhaps I wouldn’t have chosen a perlite / cement fondu mix for the dome as a lot of people advise that a castable refractory should be used as this has a higher thermal mass.
My question is...is cement fondu classed as a castable refractory (mixed with cement) or is this something completely different? Will a mix of perlite and cement fondu cause issues down the line?
If issues are foreseen, is there anything I can do to salvage my oven? I have thought about skimming the inside of the dome but I am not sure what materials I would need.
A few other questions I have if anyone can help:
- When placing my oven on top of firebricks, what are my options if I do not have the tools to cut the bricks? Could I Just build a square platform using the bricks and mortar the dome on top? Would this cause issues with heat transfer to bricks that are exposed outside of the dome? And to resolve this, would you advice that I cover the expose bricks using a refractory cement?
- Is there anything people recommend to place on top of fire bricks to provide a smoother surface or are fire bricks sufficient to cook on directly as long as they are level with no raised areas.
Any advise provider would be really appreciated.
Thanks,
Csnewton8
Thanks,
Csnewton8
