Hoping to get some advice. My oven gets plenty hot (900+F) when I build a massive wood fire, but the base never really reaches a temp to brown/crisp the crust. So I have well cooked pizza tops, but the crust is less than desired. And after the first pizza the base temps drops off.
My mistake in the construction is I embedded the fire brick base, 1/2-a-brick deep, into the 4.5” thick concrete base square. All of the concrete pulls the heat out of the fire brick.
As I think of the redesign to make larger and fix the base/heat issues, I need suggestions on the best base material to conduct the temp better? Soapstone?
I want to reuse the base concrete/fire brick base, but I hope to lay a new material atop the old embedded fire bric-in-concrete base. My question are:
1. Good material to make base for high heat conduction? Granite, clay stone, brick, 2. Is a solid piece best or better to use brick with mortise joints. What will prevent heat cracking? How thick 3/4”
2. Do I need to put an insulated material between the old concrete base and new base material? Type of insulation?
Thank for any advise Pizza Oven masters....
