2 questions:
1) I've noticed on the pictures people post some of the bricks are cut with a radius, like the bricks that form the outside perimeter of the floor that follows the shape of the FB board. How does one make such nice cuts, round and smooth. Do you use a grinder of some sort?
2) When using the IT how does its base anchor in place so it doesn't move and shift around. Do you screw it into a brick? I'm referring to the part that looks like a lazy susan.....how does that get fixed in place.
Thanks very much for the help.
. So, I think that it would best to insert the wooden anchor brick when initially placing the floor. Make sure that wooden anchor brick is as large as the the firebrick. If not use some very thin wedges to center and secure it in place.
