HI ... I'm looking to build a 36 inch (inner diameter) brick oven. I'm having a bit of trouble identifying the different terminology on FornoBravo's chart (attached).....For a 36" inner diameter oven it's showing a 45 inch outer diameter. But then it says 6 inches for insulation. Is that 6 inches part of the 45 inch outer diameter dimension? Or is it added on to the 45Inches (making the outer dimension 57 inches? Thank you for the help.
Oven's outer dimension questioin
1 PhotoJohn
______________
My Build Album: https://photos.app.goo.gl/mYnNG6wjn3VAUqkK6Tags: None
The recommended minimum blanket insulation layer thickness is 3". The 6" for insulation is referring to the overall diameter in this case, or 51". You can scribe this all out on some taped together cardboard to make a full size template that will come in very handy.
