Hi All
First time post for me, won't be the last I'm sure, any help and advice will be great appreciated.
so I've started my build and now at the stage of installing the base.
I'm using 50mm ceramic board, will I need to still use 100mm of vermiculite cement below the board?
I laid a 30mm base of vermiculite and cement mix down today more just to get a nice flat surface for the ceramic board to lay on, after i finised i started to think that i should have just gone thicker,
Is this enough insulation or should i bite the bullet and re do it and make it thicker?
I'll try and get some pis added of the build so far, not much of a pizza over yet though
chris
chris
