Newbie insulation question
  • Newbie insulation question
    Hi all - I have 3 year old half barrel WFO which I’d like to add more external insulation to. Currently have a single
    layer of CF blanket over the barrel and render/stucco finish over that.
    I’m noticing the barrel external temp gets up to 80-90 degrees Celsius when the internal temp is 400 degrees C. The oven has usually returned back to ambient temp by the morning (8-12 hours). My intention is to add additional insulation to prolong cooking time and also keep temps higher for longer when cooking pizza.
    I have about 9-10cm of room/width left to support additional insulation materials on the existing oven. My question is:
    1. Should I cover with 3-4 inches of vermiculite cement, or;
    2. Try to add another layer of CF blanket and finish with a thinner layer of render or vermiculite cement?
    I don’t wish to do a loose sand/perlite/vermiculite fill and enclose the barrel.
    TIA!
    Nino,
    Do you have any insulation below the oven floor?
    IF not, you may be loosing quite a bit of hear there as well.
    I used 2 inches of ceramic fiber blanket and 2 inches of a 10:1 vermiculite :Portland cement over my 2 inch thick dome. When my oven is at 900F inside i measure only about 80F outside.
    From what I recall the insulation properties if a 10:1 Vermiculite mix are similar to the CF blanket.
    Hope that helps.
    My oven build thread https://community.fornobravo.com/for...y-32-cast-oven
      Hi Andreas - thanks for the reply. Yes, there is CF board beneath the fire brick hearth.
      I’m not sure the thickness of the CF blanket but fairly certain it was a single layer only.
      Yours stays much cooler on the outside than mine!!!
        So, you would remove and redo the stucco, right? Then I would add another inch of blanket and use whatever room is left for vermicrete+finish.
          Yes that would be option 2 - guess I am looking for any thoughts or opinions on which would be best.
            If you have sufficient insulation under your cooking surface and just worried about insulating over/around your dome, have you considered building and enclosure/doghouse? That’s how I built my oven and it retains heat overnight for baking the following day with no issues.
              Removing the stucco and adding 2 additional layers of blanket then redo the stucco would be the best.
              Next best would be 1 additional layer of blanket and a Vermiculite/Perlite 10:1 layer then redo stucco.
              Third would be, additional blanket layer over existing stucco and another stucco outside. (Least effort)
              The difference between all 3 options would be minimum.
