Quick question on home brew mortar. I am having trouble finding specifics around the sand to know.
I know it should be silica (quartz) sand, but I am having issues determine the grain size.
I'm in Australia, which is probably what is complicating the process. I've seen that pool filter sand is ideal, and at 20/40 grade is what I should be trying to find. I THINK that is 0.8 to to 0.4mm grain size.
I can find 16/30 here, which I think is a larger, 1.1 to 0.6 grain.
I can also get c3 (which is 3mm) and c1 (which is 1mm).
I'm unsure if these sands are classed as sharp sands or not.
I can also get sand from a coatings supplier, and there sizes are SF2, F4, F6 and F8, but once again, I don't know what that means, or if they are sharp sands (I've reached out to the them, but don't have a response as yet).
So the questions are..
Would c1 pool filter sand do the job?
Is pool filter sand normally sharp sand? I thought I read somewhere that sharp sand doesn't allow for good water flow so they DON'T use it for filter sand?
I'm just a bit lost on this point, any help and advice would be awesome
