I'm in the process of making the Pompeii oven. My flooring bricks are laid in a staggered format with the dome sitting on top. This all sits on the 4" percrete insulation layer. My question is: should I cut the flooring bricks where the stick out beyond the dome so that I can wrap the whole thing (including the side of the floor) with my ceramic blanket or can I just extent the flooring bricks out to the edge of the stand and wrap just the dome. My plan is to stucco/tile as a finish. I'm just not sure if I need to have a clean break around the entire oven to prevent a noticeable heat sink.
insulation around the floor bricks?
IMHO I would take the insulation all the way down to the pcrete covering the floor bricks. What was the pcrete ratio under the floor? 2" of ceramic blanket should be the min. over the dome. A 8 to 10 to 1 precrete over the dome insulation makes a good stucco base and helps make the dome shape more consistent.
Correction: under the floor.Originally posted by UtahBeehiver View Post3" of ceramic blanket is a good amount and stucco lathe is good as well, a little hard and tricky to make the lathe a consistent dome shape though. 5 to 1 is the recommended ration under the dome with 4" equal to about 2" of CaSi
5:1 under floor
10:1 over dome
