Hi,
How do you suggest I connect the chimney to the oven? I understand the ideal method is using an anchor plate but I cannot find anything locally. Would placing the chimney and mortaring it in lead to cracking? If so how can I mount the chimney safely and securely without the use of an anchor plate?
Thanks,
Dylan
Thanks,
Dylan
. We ended up mortaring the chimney in place. We used a 150mm chimney as the oven is 27 inches internally.
