Hello all from Melbourne,
As a complete novice I am in the process of accummulating the required bits and pieces as inexspensively as I can.
I have sourced almost everything and have the opportunity to acquire 2nd hand Kiln bricks, some are around 1 Kg in weight and the others are around 3.8Kg's in weight, they are descibed as hot faced Kiln bricks and Outer Bricks
the latter are the heavier ones.
Which should I take to build the oven?
Suggestions based on your collective experience would be greatly appreciated.
Many Thanks
Many Thanks
