Im going to be building a concrete hangi pit which will be 800mm x 650mm and the pit will be 100mm wide.
Im not 100% sure of what sort of concrete design to use for this. Do i have to use bricks instead of aggregate? Or can i use general concrete mix with hydrated lime and fire clay? Will the pit be wide enough at 100ml? Should i run reo bar through the pit? or will the reo bar heat up the concrete?
Any thoughts or ideas would be appreciated
