Indoor Masonry Heater
  • v12spirit
    • Nov 2011
    • 466
    Hello dear friends.
    It has been a while and I hope life is treating you well.
    I have bought a new property and I wanted to install a fireplace in the living room.
    I have seen designes of fireplaces that insulate the walls and use fans to drift hot air from around the chimney. However, I find that a lot of waste of heat.
    Consequently, I am thinking of exploiting the massive mass of the bricks to make a masonry heater that favors a mild thermal mass so that a single firing could give heat the next day or two..
    Any one with experience in the concept of masonry heaters?
    Your suggestins and help are appreciated.
    Regards, V12spirit.
    "Why is this thus? What is the reason for this thusness?"
    I forgot who said that.
    • 5256
    Hello V12, It has been a long time, hope all is well with you and all is safe in your end of the world. Can't help you on masonry heaters other that quite a while ago several builders from the UK area used the masonry bricks from these type of heater in their ovens.
    • v12spirit
      • Nov 2011
      • 466
      Thank you UtahBeehiver, God gracefully made things end up good so far, glad to hear back from you.
