fireproofing
  • brookbend
    • Aug 2012
    • 7
    fireproofing
    I'm putting a drop-in grill into a wooden kitchen base. Can I get a way with ceramic tile left over from an oven design for heat protection of will I have to buy a [$700] stainless steel heat shield [jacket]?
    Or how else to shield?
  • Tscarborough
    • Oct 2009
    • 3341
    Re: fireproofing
    Code (in most places)=4" of masonry, 2" air gap to combustible materials.
    • brookbend
      • Aug 2012
      • 7
      Re: fireproofing
      I assume you mean EITHER 4" masonry OR 2" air ?? And the 2" applies to under the grill also? Of course this may vary on the brand of grill?
      • Tscarborough
        • Oct 2009
        • 3341
        Re: fireproofing
        No, both, but that is for interior use. Do you have a pic of your project?
        • brookbend
          • Aug 2012
          • 7
          Re: fireproofing
          no it's at another location. but it's outdoors.
          • Tscarborough
            • Oct 2009
            • 3341
            Re: fireproofing
            As a rule, outdoors and wood structures (without a roof, i.e. indoors) do not play well together. Without seeing it, all I can say is don't pay 700 bucks for a SS sleeve, but do not ignore code which is normally a MINIMUM, not the optimum.
            • brookbend
              • Aug 2012
              • 7
              Re: fireproofing
              The wood is acacia. Will not rot for 25 years. The structure is tested to hold 350-lbs. But there's a still a fire issue. I'll figure it out.
              • brickie in oz
                • 3445
                Re: fireproofing
                Acacia burns with a passion, its my preferred firewood when I go wood collecting.
                • Tscarborough
                  • Oct 2009
                  • 3341
                  Re: fireproofing
                  Is this visible wood or structural?
                  • brookbend
                    • Aug 2012
                    • 7
                    Re: fireproofing
                    my luck a guy from Australia. ok, mate.
                    visible vs structural: both
                    • Tscarborough
                      • Oct 2009
                      • 3341
                      Re: fireproofing
                      What the the brand and model? Gas or electric or charcoal?
                      • brookbend
                        • Aug 2012
                        • 7
                        Re: fireproofing
                        OCI Elite Series OCIE48BQARL 48 Built-in Professional Gas Grill - Stainless Steel
                        • Tscarborough
                          • Oct 2009
                          • 3341
                          Re: fireproofing
                          Page 8 of their manual has the information you are looking for:
                          To Combustible Construction:
                          Above and below the cooking surface, maintain a minimum of 12" from the sides and a minimum of 12" from the back to adjacent vertical combustible construction.
                          Do not install this unit into combustible enclosures without an OCI insulated jacket!
                          • brookbend
                            • Aug 2012
                            • 7
                            Re: fireproofing
                            The manual is ambiguous - 12" distance WITH or WITHOUT an insulating jacket?
                            It's probably zero distance when using their jacket. I'll have to call their engineers to be sure.
