fireproofing
  • fireproofing
    I'm putting a drop-in grill into a wooden kitchen base. Can I get a way with ceramic tile left over from an oven design for heat protection of will I have to buy a [$700] stainless steel heat shield [jacket]?
    Or how else to shield?
    Re: fireproofing
    Code (in most places)=4" of masonry, 2" air gap to combustible materials.
      Re: fireproofing
      I assume you mean EITHER 4" masonry OR 2" air ?? And the 2" applies to under the grill also? Of course this may vary on the brand of grill?
        Re: fireproofing
        No, both, but that is for interior use. Do you have a pic of your project?
          Re: fireproofing
          no it's at another location. but it's outdoors.
            Re: fireproofing
            As a rule, outdoors and wood structures (without a roof, i.e. indoors) do not play well together. Without seeing it, all I can say is don't pay 700 bucks for a SS sleeve, but do not ignore code which is normally a MINIMUM, not the optimum.
              Re: fireproofing
              The wood is acacia. Will not rot for 25 years. The structure is tested to hold 350-lbs. But there's a still a fire issue. I'll figure it out.
                Re: fireproofing
                Acacia burns with a passion, its my preferred firewood when I go wood collecting.
                My Build.
                Books.
                  Re: fireproofing
                  Is this visible wood or structural?
                    Re: fireproofing
                    my luck a guy from Australia. ok, mate.
                    visible vs structural: both
                      Re: fireproofing
                      What the the brand and model? Gas or electric or charcoal?
                        Re: fireproofing
                        OCI Elite Series OCIE48BQARL 48 Built-in Professional Gas Grill - Stainless Steel
                          Re: fireproofing
                          Page 8 of their manual has the information you are looking for:
                          To Combustible Construction:
                          Above and below the cooking surface, maintain a minimum of 12" from the sides and a minimum of 12" from the back to adjacent vertical combustible construction.
                          Do not install this unit into combustible enclosures without an OCI insulated jacket!
                            Re: fireproofing
                            The manual is ambiguous - 12" distance WITH or WITHOUT an insulating jacket?
                            It's probably zero distance when using their jacket. I'll have to call their engineers to be sure.
