Re: Trying to narrow down outdoor kitchen layout from scratch
Well let's talk about the plan a little bit because the whole thing has moved about 8 feet to the right. The idea of extending the round pad on either side to square it off on the end was rejected by the spousal design committee. She wanted it moved over a little bit, to maintain the curve in the slab. Everybody loves that round slab. I can't fault her, because I think I came up with much better alternative.
A lot of you wanted to keep the roundness of that pad, but I couldn't necessarily use it for cooking. However, I could use the roundness for serving/seating. So I sketched a semicircular seating area coming off the one corner inside the pad.
I don't know what's wrong with me that I could pretty much slap this out in Blender and make a 3d render just a little slower than if I used a 2d drawing tool, but the big perk is you can really see what I had in mind:
Things I factored in:
1. Making enough room around the pizza oven such that I'm not as liable to whack somebody in the head with the peel.
2. Having some straight area to have a sink/additional cooking device (grill/range/whatever)
3. Maintaining the general curve of the slab. I would wind up extending the slab outside of that circular area a little bit.
4. Having a curve.
Not shown is that at curved area would be recessed so legs could go under it. Spare my the time to do that little step in Blender; you get what I'm trying to do. It could theoretically be regular seating height too.
I am at a loss at how I might put a roof on that some day. I suspect it would be something like a gazebo crashing into a rectangular structure. I fear that would put a post right in the middle of the inside of that circular seating area. Most people would tell me not to worry about putting a roof on it then, but I need something to worry about or I'm not productive.
There is an issue on the far side of the circle where I linked up everything. It is a little jarring, but could be filled in with a waist-height herb garden or a shrub or something.
4. Having a curve.
