BenjaMia Bakehouse Project
  • SpringJim
    Re: BenjaMia Bakehouse Project
    I know, I know.....
  • asudavew
    Looks good Jim.
    Get some heavy cardboard and cover that floor!
    Cut it to fit!
    Trust me on that one....
    DAve
  • SpringJim
    The first course in process
    so far so good!
  • SpringJim
    Hearth
    Finished the hearthfirebricks and laid out the first course.
  • SpringJim
    Hearth time!
    I mixed a bag of fine sand with a bag of clay and dumped it on the insulating layer. This was used to give some more thermal mass and level the hearth for firebricks. I used the dry method and it worked well (so far!)
  • SpringJim
    I dunno...it was heavy! Took two people to unload it off the back of the pickup and position it in place. I can lift one side at a time to set it where I need it and shim it up to the same level as the new floor.
  • asudavew
    Originally posted by james View Post
    Nice find. That will look great.
    Indeed.
    How much did it weigh?
  • dmun
    It baffles the mind that it would have ever paid to scorp out the back of the step like that. Mind you, this was before sintered diamond saws, and that was a lot of cutting.
    Great piece.
  • james
  • SpringJim
    Granite Landing
    I found some old Granite steps from demolition of a Bank Building.
    ...gonna make a great landing!
  • SpringJim
    Perlcrete and bricks
    Insulating layer done!
  • SpringJim
    Thermocouple adaptation
    I used a plastic waterpipe piece to make a tube in the perlcrete layer.
    One at the top and one at the bottom of the insulation layer.
    Then I can install and/or remove thermocouple probes as needed!
    A little vaseline on the tube, then rotate it while the perlcrete is curing. For the top tube I covered it with a little more cement based perlcrete and will level that surface with the fireclay/sand mix before the hearth bricks are placed.
  • SpringJim
    Insulating Hearth
    I decided to use a layer of the insulating firebrick with perlcrete over it.
  • SpringJim
    Good eye Drake, the perlcrete photos are next. (That was the structural finale)
  • DrakeRemoray
    I love it! That is going to be one big oven! Also, that is some of the smoothest perlcrete I have ever seen...are you sure you added the perlite?
    Drake
