Can I use my existing propane grill to build into an outdoor kitchen?
  • Ema Rich
    • Dec 2009
    • 2
    I have a $500 grill and don't want to spend more now that I'm building my own outdoor kitchen. Also planning on making a charcoal grill too. Not sure what to do there either, but initial design will have a metal stud design with treated 4x4 corners concreted in the ground.
    kitchen faucets
  • christo
    • Feb 2006
    • 913
    Re: Can I use my existing propane grill to build into an outdoor kitchen?
    You sure can! That is exactly what I did with mine.
    Mine was a 3 unit job - I took it apart and set it into my kitchen. If you have any more questions I'm happy to help. Pics always help illustrate any problems.
    Welcome! and good luck!
    Christo
    My oven progress -
    sigpic
    • Neil2
      • Oct 2006
      • 1374
      Make sure the area under the grill is open to the air so that propane (which is heavier than air) cannot pool there.
      • Fairview WFO
        • Apr 2009
        • 68
        You certainly can, but the question is should you? If you spending all that time and effort on building an outdoor kitchen, do you want to put in an old gas grill. That's the way I started out too, but after everything else escallated, I just couldn't use that old grill.
        Actually I took apart the doors to make my oven door
        ____________________________________________
        sigpic
        • billy10388
          • Jul 2010
          • 3
          I also think so.
          Watch Salt Online Free
