Fire Starters or Fatwood Bad For Oven?
  • #16
    Re: Fire Starters or Fatwood Bad For Oven?
    Have any of you tried out Ignitonwood.com it has been some of the best stuff so far ! for me
    • #17
      Is the only reason to clean a chimney bc of fires? Do I need to clean my metal chimney?
      • #18
        I never clean mine, but maybe I should. If you hit the side of the pipe with a stick it will shower down some soot. My mobile oven has a removable flue pipe and some soot falls out of it occasionally when placing or removing it. If you have a brick chimney cleaning it would be more difficult.
        lignitonwood.com cannot be found.
