Originally posted by Dazzla
View Post
Neighbor is complaining about soot damage
Re: Neighbor is complaining about soot damage
Originally posted by Tscarborough View PostFor one or 2 pizzas, I just use the kitchen oven. I am not going to fire up the WFO for less than 4, and preferably 8 or 10. I do tend to give away a lot pizzas to neighbors, though.
Originally posted by Lburou View PostPerhaps when you are baking some bread after the pizza, you can leave some bread for the neighbors on all sides....That will go a long way to mollify any affects of smoke in any direction.
In other words, trust me, it won't work. This is war, plain and simple...but I appreciate the attempt to help me find a solution, really. Thanks.
I haven't used the oven much during the cold, dark, wet winter, just Thanksgiving and Christmas, but not pizza or bread. I'm hoping to get back into it as the season comes back around. We'll just have to see what happens.
I'm thinking she is complaining about it because she is jealous that you have a WFO and she has not been invited over for a pizza
That's why a small oven is an advantage. We don't mind firing the oven for two pizzas because it uses such a small amount of wood. Mine takes 4Kg of wood to reach 350C
I don't mind the time prepping the dough. It's the chopping wood and two hours stoking and feeding a fire all to cook pizzas for two or three minutes that gets a little vexing.
John
Originally posted by kebwi View PostThanks.
Yeah, I desperately want to do some pizza. On an unrelated note, I am somewhat dismayed at the time and effort required to make one or two pizzas for my wife and myself. I don't mind the time prepping the dough. It's the chopping wood and two hours stoking and feeding a fire all to cook pizzas for two or three minutes that gets a little vexing. I love doing pizza parties, but for just the two of us I am learning that I have to overcome a lot of inertia to do pizza...especially during winter.
I should try to put together a pizza party later this month.
Cheers!
I wanted to build the oven outside, but have the oven landing in the dining room . There was one vote "NO" and that vote has 51% count this time
I've studied your web sites and marvel at the quality of your build. Exceptional in every way. I noticed the confined spaces you have to deal with, you do really have some challenges to overcome.
My best to youLast edited by Lburou; 01-03-2011, 09:12 AM.
Sorry I see I'm a bit late on the Fire Marshal and regulations.
Found another a bit old but still informative note the old wording changed in the previous document. This is the law so if the neighbor is complaining there is really nothing she can do but complain. In this one you would follow the Patio Fireplace regulations.
You have every right to continue using your oven.
Just noticed, this notice is 2006 and the change in wording on the regulations was changed and adopted in 2004. Funny the fire department doesn't check for regulatory updates.Last edited by Faith In Virginia; 01-03-2011, 08:52 AM.
This is something you should really look at at this point. Amendments to your local fire code.
Seattle City Council Bills and Ordinances
It's an earlier version of your local fire codes but most don't change that much but check with your local Fire code official not the building inspector for a current reading of your local codes. You can read through this entire document and may find other things to your benefit but this is what I found on a quick glance. These are just changes adopted by your local government from one fire code to a newer version.
Section 80. Section 302.1 of the 2003 International Fire Code is amended as follows:
302.1 Definitions. The following words and terms shall, for the purposes of this chapter and as used elsewhere in this code, have the meanings shown herein.
RECREATIONAL FIRE. An outdoor fire burning materials other than rubbish where the fuel being burned
(is not contained in an incinerator, outdoor fireplace, barbeque grill or barbeque pit and) this section striked out
has a total fuel area of 3feet (914 mm) or less in diameter and 2 feet (610 mm) or less in height for pleasure, religious, ceremonial, cooking, warmth or similar purposes. A recreational fire may be contained in an incinerator, outdoor fireplace,barbeque grill or barbeque pit.
Like I said find your local fire code official and perhaps you can get a letter from him to state that you are within fire code regulations for your location. Here is where you find him
MESINSLOT adalah platform slot gacor dengan perkalian x500 yang mudah didapat. Dijamin cuan dengan RTP tinggi dan peluang menang besar setiap hari. Daftar sekarang dan login mesin slot.
Hope this helps
Originally posted by david s View PostBlowing smoke up someones arse was a recommended method for resuscitating drowning victims in England in the 18 th C. Maybe you could try the technique on your neighbour.
A length of pipe (8mm copper is really good) you can easily ignite smouldering wood to eliminate smoking. The great thing about it is that you can direct the oxygen to exactly the spot you want. It's also a really easy way to clear the ash from the floor.
I rather doubt I'd get that true Neopolitan pizza flavor without the wood-fire next to it...not that I know what I'm talking about.
